2000 Dodge Durango Coolant Leak on Floor
LTIMMONS
I have a 2000 Dodge Durango V-8 5.2. I just had a new evaporator put installed. In about a week the air conditoner just sstopped working so I took it back in and the mechanic said it was plugged up. He said he fixed it. About week later I noticed that collant had leaked onto the driver side floor. I have taken the car back twice since then and it still isn't fixed. The mechanic said he can't find a leak but the coolant has to be leaking from somewhere. It seems to only leak when the car is being driven. It is still leaking and I will have to make another trip to the mechanic. Do you have any ideas? Could the mechanic have poked a hole into something while unplugging it? My husband just passed away a couple of months ago or he would be handling this. Needless to say I am clueless and so apparently is the mechanic.
Sep 4, 2007 at 10:09 AM
MERLIN2021
  • 17,250 POSTS
Check the hose clamps at the firewall where they enter the inside, make sure they were replaced with the screw type relacement, if you still have the spring clamps on they were not replaced...this is a comon place for a leak! Don't over tighten, you can crush the new heater core inlets...
Oct 16, 2020 at 4:48 AM
Suggested Repair
Inspect the heater hose clamps at the firewall where the hoses enter the cabin. Confirm they were replaced with screw-type clamps rather than left as spring clamps, a common leak point. Do not overtighten them, which can crush the heater core inlets.
Conversation Summary
A 2000 Dodge Durango began leaking coolant onto the driver-side floor after evaporator and air-conditioning work. The leak appears mainly while driving, and the mechanic has not found the source. The expert advises checking the firewall heater hose clamps, ensuring screw-type replacements were installed, and avoiding overtightening that could crush the heater core inlets.
