Coolant loss/leaking
2002 DODGE DURANGO
160,000 MILES • V8 • 4WD • AUTOMATIC
JSIEBER
I recently had to refill the coolant after the truck overheated one day. I initially replaced any easily serviceable items (water pump, thermostat, radiator cap), and had the radiator pressure tested while it was out. I have noticed that the coolant level is steadily going down despite all of this. So I've performed a few tests:
Pressure tested the cooling system, and after filling it to 19-20 psi, it steadily looses pressure after a few minutes.
I ran a compression test, which seems normal, however the number 2 plug always comes out wet and the others appear dry.
In addition I have been getting cylinder two misfire codes.
Lastly, I have noticed occasional sweet smell from exhaust.
What is the most likely cause, Head, Head gasket, intake gasket?
Nov 22, 2009 at 3:16 AM
MATHIASO
  • 1,209 POSTS
Hello jsieber, The most likely cause is the head gasket. Here is the different between the intake the head gasket. The intake Manifold gasket is the gasket that seals the intake manifold to the cylinder heads, if leaks, it may allow coolant to enter the intake port, crankcase or dribble down the outside of the engine. your engine is not wet around. so it is not the intake gasket. it is probably your head gasket you did a good jo9b with the compression test. leaking cylinder #2 with wet spark plug.that is in the head. For the cracked Head or Block, this dilutes the oil on the cylinder walls and can damage the piston and rings. If the coolant contains silicates (conventional green antifreeze), it can also foul the oxygen sensor and catalytic converter. If enough coolant leaks into the cylinder (as when the engine is sitting overnight), it may even hydro-lock the engine and prevent it from cranking when you try to start it. A coolant leak into the crankcase is also bad news because it can damage the bearings. Coolant leaking into the crankcase will make the oil level on the dipstick appear to be higher than normal. The oil may also appear frothy, muddy or discolored because of the coolant contamination Now let's come back to our situation. The problem is the head gasket one. it can be verified with performing cylinder leakage test it is more accurate than compression test.
https://images.2carpros.com/forum/automotive_pictures/46384_leakdown_tester_1.jpg
A leak down test requires the removal of all the spark plugs. The crankshaft is then turned so that each piston is at top dead center (both valves closed) when each cylinder is tested. Most people start with cylinder number one and follow the engine's firing order. A threaded coupling attached to a leakage gauge is screwed into a spark plug hole. Compressed air (80 to 90 psi) is then fed into the cylinder. An engine is great condition should generally show only 5 to 10% leakage. An engine that's still in pretty good condition may show up to 20% leakage. But more than 30% leakage indicates trouble. if there is leak,it can be pinpointed by just listening: -Oil filler:leaking rings or piston -Air cleaner:leaking intake valve -Exhaust: leaking exhaust valve -Bubbles in the radiator:blown head gasket Hope this information help.
Oct 16, 2020 at 4:47 AM
JSIEBER
Will a cracked head be obvious if present, or should I have them checked out (Xray'd I presume as they are aluminum?)
MATHIASO
  • 1,209 POSTS
Ask them to check the cylinder # 2, that is where our problem is located.Do not give them more ideas to suck money out of you with diagnosis.
For your question, yes a cracked head would be obvious . Aluminum heads are especially vulnerable to warpage and cracking because aluminum has a much higher coefficient of thermal expansion than cast iron. Consequently, when a bimetal engine with an aluminum head gets too hot, the head tends to swell up in the middle, causing it to warp and blow the head gasket.
I believe it is the head gasket, have it check and let me know.
