2001 Dodge Durango leaking coolant
2,000 MILES • V8 • 4WD • AUTOMATIC
SARA0611
my 01 dodge durango is leaking coolant. at first i just thought it was a hose. the antifreeze is on the ground right under the radiator (the radiator was replaced already, also replaced upper radiator hose) but the other day after not driving it for 2 days i went to check it and there was a puddle of antifreeze in the middle under the engine and antifreeze on the engine. the engine is new remanufactured 0 miles now with about 2000. what could this be? water pump?
May 12, 2010 at 2:23 AM
MERLIN2021
  • 17,250 POSTS
Yes it could be the pump, but Autozone has a loaner tool program, go get a coolant system pressure tester, pump it to the pressure listed on the cap, leaks, and where they are coming from will be real e-z to spot...
Oct 16, 2020 at 4:47 AM
