2002 Dodge Durango Rear Defrost Blinking
ROSSSUGAR
2002 DODGE DURANGO
ENGINE 4.7L
MILEAGE-80,653
Mechanic recently installedcooling fan relay and emc computer. Now the rear defrost light is flashing. Did any of the above installations cause my defrost to go out? They said they did not pull out the dash? What happen? Air and rear defrost was working fine.
If their work caused me more money, please explain so I can explain to them. I am to leave my car with them on Monday.
May 11, 2007 at 11:31 AM
2CARPRO JACK
  • 11,533 POSTS
Ther is a relay in the underhood center next to the PCM they replaced, possibly the probem lies there. Check fuse 4 in the underhood power center,fuse 24 and 15 in the fuseblock at the left end of the dash (inside car)
May 13, 2007 at 1:49 AM
Suggested Repair
Check the relay in the underhood center next to the PCM, fuse 4 in the underhood power center, and fuses 24 and 15 in the interior fuse block at the left end of the dash.
Conversation Summary
The owner of a 2002 Dodge Durango says the rear defrost light began flashing after a mechanic installed a cooling fan relay and EMC computer. Rear defrost and air conditioning had worked before, and the dash was not removed. The expert suggests a nearby underhood relay may be involved and recommends checking fuse 4 in the underhood power center plus fuses 24 and 15 in the dash fuse block.
