Crankshaft position sensor
TAJSE
V8 four wheel drive automatic 119,000 miles.
where is crankshaft position sensors location?
May 18, 2008 at 6:02 AM
BMRFIXIT
  • 19,053 POSTS
Crank position sensor location:
4.7L engine on right rear side of cylinder block.
5.2L and 5.9L engine on top of cylinder block near rear of right cylinder head.
May 18, 2008 at 11:52 AM
DILSMACK
The Chilton manual I have is pretty vague. On the 4.7L V8, if your standing in front of the car, follow the exhaust manifold down to where it starts to go under the car, that is where the sensor is located, under the car. You will have to crawl under and unscrew it. It is held on with a single bolt with a three pin electronic connector on top. The sensor itself is pretty much just a magnet. It will be close to where the transmission mounts to the engine. Hope this helps.
Dec 28, 2008 at 5:15 PM
