2004 Dodge Dakota Won't Start
KKWHEELER
I have a 2004 Dodge Dakota, V-8, 74,000 miles.
When you turn the ingnition switch to the start position, nothing happens. Battery is good, lights do not dim when trying to start. There are no clicks or any sounds when trying to start. Checked all fuses. Any help would be appreciated.
Dec 13, 2006 at 7:16 AM
BACKYARDMECHANIC
  • 337 POSTS
The fact you tell me nothing happens and the lights DON"T go dim leads me to believe you have a problem with the cables or connection at the starter. Check the battery terminals and make sure they are tight and clean. Then see if it starts. If not check the connections on the starter, make sure they are tight. The only other thing I can think of is the ignition switch is bad, but this is unlikely your probably. Hope this helps :o Backyardmechanic
Dec 14, 2006 at 6:00 AM
Suggested Repair
Clean and tighten the battery terminals, then check that the starter cable connections are tight and secure. A failed ignition switch is possible but less likely.
Conversation Summary
A 2004 Dodge Dakota V8 with 74,000 miles does nothing when the key is turned to start: no click, no crank, and the lights do not dim. The battery is good and the fuses were checked. The expert advised checking for loose or dirty battery terminals and starter cable connections, and considered a bad ignition switch unlikely.
