Truck was running fine until fri. Tried to start and engine just barely turned then had no power at all. No lights, horn, ignition. Tried to jump it-same results. Battery is six mos. Old and tests out at specified voltage. Terminals are clean and tight and all grounds off of the battery test ok. Replaced the fusible links for the a/c and alternator. Still no power at all. On a whim, tried to jump it again. Fired right up and ran fine for a day and started several times. Sun aft. I was right back where I started. No power to anything. Jumped it again, had power back to everything. Started up fine but was idling very erratically. When I put it it gear, it died with no power to anything again. Let it sit for a while jumped it and let the other car run for a while without starting the truck. Had interior lights and everything but when I tried to start. Back to no power to anything. Am stumped!
SPONSORED LINKS
Monday, June 18th, 2007 AT 5:57 PM
