1995 Dodge Dakota No Start
For what it matters, Ignition wires can get stressed out from a weak cap and rotor, Not that this is your case or not.
Suggested Repair
With the key on, listen at the fuel filler neck for the fuel pump to hum. If it is silent, spray starting fluid into the throttle body while cranking. If the engine runs only while spraying, the problem is fuel delivery, such as the fuel pump or auto shutdown relay. Also consider ignition wires damaged by a weak cap and rotor.
Conversation Summary
A 1995 Dodge Dakota 2.5L began hesitating, losing power, and dimming the lights, then would not start after the battery terminals were cleaned. The owner replaced the coil, pickup coil, distributor, and a burnt rotor, but spark still appeared only briefly. A code 12 after battery disconnect no longer flashed. The expert advised listening for fuel-pump prime and using a starting-fluid test to confirm a fuel-delivery fault, and noted that weak ignition parts can stress the plug wires.
