1995 Dodge Dakota will not start
RODNEY CAREY
  • 1995 DODGE DAKOTA
Engine Mechanical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic
what can I do to git it to start.
Sunday, April 5th, 2009 AT 8:41 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, April 5th, 2009 AT 8:48 PM
BMRFIXIT
  • 19,053 POSTS
Need to find the reason why 1st
have to check for spark
check for fuel and fuel pressure
check fuses and relays (ASD relay)
Sunday, April 5th, 2009 AT 8:50 PM
