2002 Dodge Dakota Cranks But Won't Start
TIMMYG1
i have a 2002 dodge dakota v6 2 wheel drive. the problem is i started to drive down my driveway and then it shut off now i cant start it the engine cranks but it wont start any ideas?
Jan 8, 2007 at 5:56 AM
BOOTDOG
  • 665 POSTS
there are several different possibilities it could be. it could be the fuel pump, fuel pump relay, ignition coil, ignition moduel, just to name a few. before cranking the vehicle, turn the key to the on position and see if you hear the fuel pump. it'll sound like a high pitch whine. you can also tap on the fuel tank with a hammer, then see if it'll start. if so replace the fuel pump. if it doesn't start the pump could still be the problem. if the vehicle is getting fuel then look into seeing if the vehicle is getting spark. if your not sure how to check for spark, find someone who does know. you can shock yourself if you don't do it correctly. let me know if you want do it yourself and i'll try to guide you through the best i can. good luck
Jan 8, 2007 at 7:34 AM
Suggested Repair
With the key on, listen for the fuel pump prime whine. If tapping the tank lets it start, replace the fuel pump; also check the fuel pump relay. If fuel is present, check for spark and inspect the ignition coil and ignition module.
Conversation Summary
A 2002 Dodge Dakota V6 2WD shut off while driving and now cranks but will not start. The expert listed possible causes including the fuel pump, fuel pump relay, ignition coil, and ignition module, and advised listening for the pump with the key on, trying a tank tap test, then checking for spark if fuel is present.
