2002 Dodge Dakota engine turns over but won't start
THECAPTAIN4EVER
  • 2002 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 85,000 MILES
After replacing the battery, the motor turns over, but will not start. The fuel pump can be heard running when ignition is engaged
Monday, November 30th, 2009 AT 9:48 PM
Do below to determine if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
_________________
Thursday, September 7th, 2017 AT 5:27 PM
