2002 Dodge Dakota Engine won't start
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
RMBLNJOE
2002 Dodge Dakota, 109,000 miles, 3.9 L V-6, has been running fine. Went to start the engine today, turned the ignition key, there was a popping sound, and then nothing. It doesn't grind, or anything. If I leave the key in the on position, the radio will turn on. The battery is only a year or two old, and in good shape. Any possible suggestions will be gladly appreciated.
Jun 10, 2010 at 9:16 AM
  • 75,988 POSTS
Check the condition of the battery by load testing it and also the connections-if okay could be a security issue or the ignition switch problem-
No crank at all/nothing/nada:
Could be a blown fusible link, the starter, starter relay/park and neutral switch and ignition switch assuming the battery and connections are good.
Jun 10, 2010 at 10:06 AM
RMBLNJOE
rasmataz,
Thank you for your prompt reply.
RmblnJoe
Jun 10, 2010 at 11:52 AM
RMBLNJOE
It was a bad battery. Thank you for your help.
RmblnJoe
Jun 10, 2010 at 2:58 PM
