'97 Dodge Dakota won't run
JONEILL4
  • 1997 DODGE DAKOTA
I have a 97 Dodge Dakota 2wd 6 cylinder automatic with 125000 miles
Before it wouldn't idle then it sat for a few months and now it won't start. I figured it had to be fuel related (the battery died also) when I get power to it there is fuel at the rail so does that suggest the injectors? I know fairly little about fuel injection and even less about modern computer/sensor things so I am lost!
Thanks!
Wednesday, May 30th, 2007 AT 1:04 PM
E40WATER12
  • 522 POSTS
Best thing to do is to get a fuel pressure test done to the fuel pump, Then I would recommend getting youre filter changed. See what happens from there, Also make sure youre battery is fully charged, Also thats youre charging system is working correctly as well.
Thursday, May 31st, 2007 AT 5:37 AM
