2000 Dodge Dakota Will not start
RMCLUBB
  • 2000 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 140,000 MILES
Truck just sputtered and stopped, and would not restart, not getting any power to coil or fuel to cylinders. Coil and fule pump only have power for a couple of seconds after turning the key on then nothing. I supect the ECM is bab but do not want to spend $300 if that is not the cause. I replaced rotor and cap with new and inspected spark plugs which were dry after repeated attempts to start the truck.
Saturday, July 31st, 2010 AT 9:46 PM
  • 110,182 POSTS
Open up the wiring harness at the ECM. You will find a white wire with a red tracer. Aprox a foot down the wire is a splice. They are known for corrosion problems and shutting both fuel and spark off.
Let me know what you find.
Tuesday, February 14th, 2017 AT 10:29 AM
