2000 Dodge Dakota hit pot hole stalled, no start
CEK
  • 2000 DODGE DAKOTA
Computer problem
2000 Dodge Dakota 4 cyl Two Wheel Drive Manual 100k miles
Hit a pot hole stalled, no start, cranks good, I can hear fuel punp run when I cyle the ignition code p0443 It has no spark fuel ok?
Friday, January 9th, 2009 AT 8:39 PM
  • 109,885 POSTS
Hi:
Have you checked for power to the coil?
Tuesday, February 14th, 2017 AT 10:30 AM
CEK
  • 20 POSTS
Yes checked power to coil ok and inj is ok, still no spark?
CEK
  • 20 POSTS
Power to coil ok also inj palse ok ?/
  • 109,885 POSTS
Hi:
Code p0443 is evap purge solenoid circuit, at least that is what I found. I don't see how that would cause no spark. Take a look at the crank sensor for damage. I think we have an electrical problem (something loose from the bump). Now the trouble is finding it. Start at the sensor and see it's condition. Was the bump bad enough that something could have been damaged under the vehicle?
