2000 Dodge Dakota V8 Four Wheel Drive Automatic
motor will turn over and not start checked fuses inside and under hood odometer will reed no bus, tested and got codes 920,921,999. Heard vibration in under hood fuse/relay box. Switched relays around no help. The relay vibrating the most was auto/shutoff I TOOK TOOTH PICK AND MADE THE CONTACT THAT THE RELAY PICKS IN THE RELAY ITSELF AND THE TRUCK STARTS AND RUNS NORMALLY. But I know I am bypassing something. Took all fuses out and checked, body grounds that I could find, connections on pcm, could not find ctm under dash, pushed and moved wires around under dash. Also when I put the truck back in Two wd I get a lot noise, scraping vibration in front wd. Pushed shifter f@b will moving with no help.
SPONSORED LINKS
Friday, February 6th, 2009 AT 6:31 PM
