1997 Dodge Dakota Check Engine Light
LABBY
  • 1997 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 265,000 MILES
The check engine light keeps coming on indicating a general misfire on cylinders 1, 3, 5, which are all on the sa. Me side of the engine. I have replaced spark plugs, plug wires, distributor cap and rotor. The light goes out for awhile, but always comes back on within 50 miles or less. The plugs are still in good shape when I check them and they are not burnt, corroded or oiled. Any ideas? Thanks!
Also, does a 1997 Dakota have a cabin air filter?
Wednesday, October 8th, 2008 AT 10:20 PM
  • 109,885 POSTS
Hi:
when the light comes on, how does the vehicle run? No cabin air filter.
Thursday, October 9th, 2008 AT 8:51 AM
LABBY
It runs just fine. I don't notice any difference in operation, just that I notice that the light comes on. The only noticeable difference is in the mileage, which is not the best in the industry to begin with, but it gets worse after the light comes on. Could a loose vacuum line cause this? I am willing to try anything at this point. Thanks!
Thursday, October 9th, 2008 AT 5:08 PM
  • 109,885 POSTS
Hi:
Have you checked the o2 sensor?
Thursday, October 9th, 2008 AT 6:05 PM
LABBY
Yes, both are working.
Friday, October 10th, 2008 AT 7:43 PM
  • 109,885 POSTS
Hi Again:
I will assume that you had the computer scanned to no avail. My guess then is it may be a vacuum leak or the ECM may be starting to go bad.
Let me know if you have any other questions. Also, make sure to look for a vac leak.
Sunday, October 12th, 2008 AT 8:58 PM
