1995 Dodge Dakota
KCOFFIN
  • 1995 DODGE DAKOTA
Engine Performance problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic
I have a 1995 dakota v6 that starts very well when cold. After driving and shutting off, it will start right again, but after 20-30 minits, sometimes it will turn over but wont start If I leave it sit for 15 min. It will start right up. I put new plugs, wires, cap and rotor, andignition coil on. This truck has 152,000 on it I would appreciate any input on this
Friday, October 30th, 2009 AT 2:21 PM
JDL
  • 16,098 POSTS
Welcome, if it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Can you check for codes?
Friday, October 30th, 2009 AT 2:27 PM
