1993 Dodge Dakota wont start
BRIDGETGIDGET
  • 1993 DODGE DAKOTA
Electrical problem
1993 Dodge Dakota 6 cyl Two Wheel Drive Automatic
i changed the water pump on my 1993 dodge dakota it started after we finished several times then it just died now it cranks but wont start we changed the coil nothing. Crank sensor. Nothing. Halofax nothing we checked fuses its not getting any fire now what I dont understand
Sunday, October 25th, 2009 AT 8:12 AM
  • 109,901 POSTS
If you are not getting spark, it could be several things. First, are you getting power to the coil? Also, have you checked the crankshaft sensor? It's located in the center of the rear engine area above transmission bellhousing. It's mounted on upper rear of engine block
Friday, November 6th, 2009 AT 11:28 AM
