HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Engine
Symptoms
Not Running
SPONSORED LINKS
1993 Dodge Dakota will not start
CENTRAL AUTO REPAIR
MEMBER
1993 DODGE DAKOTA
Engine Mechanical problem
1993 Dodge Dakota 6 cyl Two Wheel Drive Automatic
I have no fuel pressure, and spark. I have replace the ecm and fuel pump. Changed the pickup coil and still nothing. Any ideas?
Tuesday, June 17th, 2008 AT 12:40 PM
LEGITIMATE007
MECHANIC
The car will turnover but will not start right?
SPONSORED LINKS
Tuesday, June 17th, 2008 AT 1:45 PM
CENTRAL AUTO REPAIR
MEMBER
Yes it will.
Tuesday, June 17th, 2008 AT 2:22 PM
LEGITIMATE007
MECHANIC
Check fuel pressure relay first.
Tuesday, June 17th, 2008 AT 8:37 PM
LEGITIMATE007
MECHANIC
Check crank position sensor also
Tuesday, June 17th, 2008 AT 8:38 PM
LEGITIMATE007
MECHANIC
How is the coilpack? Or is this a distributor system?
SPONSORED LINKS
Tuesday, June 17th, 2008 AT 8:40 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1993 Dodge Dakota Truck Cranks But Does Not Want To...
Bought This Truck For My Son, Ran Just Fine For Last 3 Weeks, Then I Added Some Fuel Additive/cleaner. Truck Then Started To Have Trouble...
Asked by
chuck best
1 ANSWER
1993
DODGE DAKOTA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1993 Dodge Dakota Will Not Start
Died While Driving, Put In New Pick Up Coil, Will Not Start. Checked Coil, It Is Good, Still No Spark. Any Ideas?
Asked by
jrsurohlfs
1 ANSWER
1993
DODGE DAKOTA
1993 Dodge Dakota Starts Sometime And Not Sometimes
I Have Changed The Crank Sensor, And The Pickup Coil Under The Distributer Cap. Check Engine Light Has Not Come On. The Starter Is Spinning...
Asked by
ewgivens
1993
DODGE DAKOTA
1993 Dodge Dakota Wont Start
Electrical Problem 1993 Dodge Dakota 6 Cyl Two Wheel Drive Automatic I Changed The Water Pump On My 1993 Dodge Dakota It Started After...
Asked by
bridgetgidget
1 ANSWER
1993
DODGE DAKOTA
1993 Dodge Dakota Truck Won't Start
I Drove To Work, Parked Did My 14 Hrs Shift. When I Went To Start It Up Turned Key Got No Response. Checked Battery, Good, Put Key In Run...
Asked by
captbobert
1 ANSWER
1993
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
