I replaced the coil and that did not fix it. It will turn over but is not getting any fire. Any suggestions?
Tuesday, March 10th, 2009 AT 8:09 PM
MECHANIC
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
