1992 Dodge Dakota I have trouble codes 11, 12, 22, 32, 37 and
DAVE BRILLHART
'92 5 speed was quitting and finally would not start. Needed a break so I disconnected the battery. No codes and so far running perfectly. Had replaced several coils and a crank sensor.
Wednesday, January 25th, 2017 AT 4:17 PM
CARADIODOC
  • 33,916 POSTS
You need to start a new question, and PLEASE list the engine size when you have an engine running problem. This is a conversation between just two or three people. When you piggyback onto it, none of the other experts will see it or have a chance to reply. That does you a disservice. Also, your description is real confusing. Why did you disconnect the battery? Doing that erased any diagnostic fault codes, so that valuable information is long gone. The common codes related to crank / no-starts often don't set from just cranking the engine. They set while a stalled engine is coasting to a stop. If the engine is running perfectly, what is the question?
Thursday, January 26th, 2017 AT 7:13 PM
