1992 Dodge Dakota Why do i have engine code 37?
GREENCHEVYMALIBU
  • 230 POSTS
Transmission problem
1992 Dodge Dakota 6 cyl Two Wheel Drive Automatic 168xxx miles
The torque converter locked up so i replaced it. I also replaced the solenoid on the valve body. Why am i getting code 37? How can i fix this?
Mar 19, 2010 at 11:55 AM
  • 75,988 POSTS
Hi greenchevymalibu, Welcome to 2carpros and TY for the donation
Could be a bad wiring or the torque converter lock-up relay -inspect and test if okay have the transmission control module tested if separately from PCM/SBEC
https://www.2carpros.com/forum/1993-plymouth-acclaim-dtc-37-vt388345.html
Mar 19, 2010 at 12:41 PM
GREENCHEVYMALIBU
  • 230 POSTS
i replaced torque converter lock-up relay. i just took off the pigtail to the torque converter lock up relay/splenoid and cleaned it. i will see what it does. i will post what happens. thanks.
Mar 19, 2010 at 1:16 PM
GREENCHEVYMALIBU
  • 230 POSTS
i cleaned the pigtail. and it drives fine now. it doesn't slip but i still have the engine codes why?
Mar 21, 2010 at 9:36 AM
  • 75,988 POSTS
You probably need a DRB2 to clear the code.
Could be a problem with the SBEC not providing the ground circuit to the TCC solenoid or a wiring problem to the TCC solenoid
Mar 21, 2010 at 10:04 AM
