1989 Dodge Dakota
STANTHEMAN08
  • 1989 DODGE DAKOTA
  • 6 CYL
  • 140,000 MILES
My truck just quit on me when I was driving it I had it towed home I thoght it was not geeting any fule so I replaced the fule pump and the fule filter it still would not start so I deturmend it wasent geeting any spark so I put a coil on it still would not start I put a complete tune up on it last winter 07 but wen I was meesing with the distributer I nostesed it looked bad so I replased that and the rotor button still does not start could you tell me what els it could be
Tuesday, October 21st, 2008 AT 8:25 PM
  • 109,885 POSTS
Hi:
Are you getting power to the coil? Also, have you checked the computer for codes?
Tuesday, October 21st, 2008 AT 8:35 PM
STANTHEMAN08
Ya there is power to the coil and we cant read the codes because it wont start to see iff the engin light evan comes on
Thursday, October 23rd, 2008 AT 7:21 PM
  • 109,885 POSTS
Hi Again:
Are you getting spark to the plugs and fuel to the injector?
Also, I want you to try something. Cycle the ignition switch from off to the run position 7 times, then back to off. See if the engiine light flashes. If it does, count the number of flashes. There will be a delay between numbers if it works correctly.
Thursday, October 23rd, 2008 AT 8:36 PM
