1990 Dodge Caravan Tail Lights Out
CHEFJOSCH
On my 1990 Dodge Caravan SE the tale lights and standing lights doesn't work! I checked the bulbs and the fuses. They are OK! What else can I do?
Thx for helping me!
Mar 13, 2006 at 2:45 AM
RAYHUT
  • 134 POSTS
have you checked all of your bulbs around your van.one bulb blown can couse a number of lights not to work. then again it might be a inline fuse blown that goes to your tail lights.and if that's not it invest in a new light switch couse your switch has gone bad one sid controls all your front lights the other side controls the back lights.
Mar 13, 2006 at 10:39 PM
CHEFJOSCH
Hey rayhut,
I have checked all of the bulbs! And all are OK! I want to check my inline fuse, but I don't know where I can find it. Can you tell me that?
Thx
Mar 16, 2006 at 4:39 AM
Suggested Repair
After confirming all bulbs and fuses are good, check the inline fuse that feeds the tail lights. If that fuse is intact, replace the light switch; one side controls the front lights and the other controls the rear lights.
Conversation Summary
The owner of a 1990 Dodge Caravan SE reported that the tail lights and standing lights do not work. The bulbs and fuses were checked and found good. The expert said one failed bulb can disable several lights, suggested checking the inline fuse for the tail lights, and advised replacing the light switch if the fuse is good because one side controls the front lights and the other controls the rear lights. The owner confirmed all bulbs were good and asked where the inline fuse is, but that location was not provided.
