2000 Dodge Caravan Power Mirror Replacement Fix
ANDERSENJ1
The power mirror on the drives side of my 2000 Grandcaravan was crushed. I bought a new mirror, but how do take the old one off? Should it pop off from the outside or am I going to need to remove some panaling from the inside?
May 25, 2007 at 7:36 AM
E40WATER12
  • 522 POSTS
Yes in the inside of the driverside door u will see a traigle looking piece, Either their are screws showing or u have to pop off the panel with a screw driver, Then their should be a bolt or few screws holding it in place, Once those a re removed, just unplug the wiring harness, pop in the new unit in reverse steps, then youre set.
May 27, 2007 at 5:06 PM
Suggested Repair
From inside the driver's door, remove the triangular trim piece (screws or a screwdriver pop-off). Remove the bolt or screws holding the mirror, unplug the wiring harness, and install the new mirror in reverse order.
Conversation Summary
The owner of a 2000 Dodge Grand Caravan crushed the driver-side power mirror and asked whether it comes off from outside or requires interior panel removal. The expert said to access a triangular piece inside the driver's door, remove screws or pop the panel, unbolt the mirror, unplug the harness, and install the new unit in reverse.
