2000 Dodge Caravan Lost Power Steering
DEBWOMAN
2000 Dodge Caravan, 114,000 miles, v6.
For the past week, there has been a noise upon starting the car. Goes away in about a minute or two. Tonight, I drove the car about two miles and heard a "pop" and lost power steering. Engine was running fine. Could go forward and reverse. No steering, though.
Picked up some fluid hoping I had just run out of fluid. Put it in, let it run for 5-10 minutes and nothing.
Please help. Thanks!
(BTW, I'm having trouble with your paypal form ...)
Feb 24, 2007 at 1:36 PM
CHEVY22
  • 1,375 POSTS
this is just an educated guess from your statement it sounds like the p/s pumpshaft may have broken internally , this would still allow the pulley to move but the pump would not have pressure , you can do a backyard test by removing the cap and pinch off the high pressure side and if you have fluid blowing out of the pump its ok if no fluid the pump is not pumping and as i said may have broken the pumpshaft internally , oh btw watch you eyes if you do pich a line off it gets messy
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge the feed back is like a thank you
Feb 24, 2007 at 4:12 PM
DEBWOMAN
[quote:1123578b87="CHEVYII"]this is just an educated guess from your statement it sounds like the p/s pumpshaft may have broken internally , this would still allow the pulley to move but the pump would not have pressure , you can do a backyard test by removing the cap and pinch off the high pressure side and if you have fluid blowing out of the pump its ok if no fluid the pump is not pumping and as i said may have broken the pumpshaft internally , oh btw watch you eyes if you do pich a line off it gets messy
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge the feed back is like a thank you[/quote:1123578b87]
Thanks for your help, Jim. I'm assuming (a dangerous thing, I know) that this is going to be a costly fix. Now, I need to find a mechanic I can trust.
Feb 24, 2007 at 9:03 PM
CHEVY22
  • 1,375 POSTS
no it really wont be that bad , the pump from the dealer is 179.00 and labor is 3.0litre 1.6 hrs and the 3.3 litre is 3.4 hrs to install , plus fluid of course , good luck with everything
take care
jim
Feb 25, 2007 at 1:46 AM
DEBWOMAN
[quote:fbb9f89b1f="CHEVYII"]no it really wont be that bad , the pump from the dealer is 179.00 and labor is 3.0litre 1.6 hrs and the 3.3 litre is 3.4 hrs to install , plus fluid of course , good luck with everything
take care
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge[/quote:fbb9f89b1f]
Jim,
Thanks again ... feeling a bit better about things. :-) Left you feedback this morning.
Make it an awesome day!
Deb
Feb 25, 2007 at 1:49 AM
CHEVY22
  • 1,375 POSTS
hey thanks and the best of luck
jim
Feb 25, 2007 at 2:08 AM
Suggested Repair
Test whether the power steering pump is producing pressure by removing the reservoir cap and briefly pinching the high-pressure line while watching for fluid movement; protect your eyes. If there is no output, replace the pump and fluid. A dealer pump was quoted at about $179, with labor of about 1.6 hours for a 3.0L or 3.4 hours for a 3.3L.
Conversation Summary
The owner of a 2000 Dodge Caravan reported startup noise for about a week, followed by a pop and sudden loss of power steering while the engine continued to run. Adding fluid did not restore assist. Expert Jim guessed that the power steering pump shaft had broken internally and suggested a backyard pressure test. He estimated a dealer pump at $179 plus fluid, with labor of 1.6 hours for a 3.0L or 3.4 hours for a 3.3L. The owner thanked him and planned to find a trusted mechanic.
