1994 Dodge Caravan No Fuel Pump Power
SHELLYGENELUCAS
My 1994 Dodge Caravan quit running. I took it to the shop, but the mechanics didn't think it was worth repairing. They said that when the applied power to the fuel pump it wouldn't kick on. They also said that they were not getting power out of the electrical plug to the fuel pump. So in order to fix it they would have to pull the dash and stuff to find it. Is there any way to reroute power to the pump? And does that mean that the fuel pump is also bad?
Dec 29, 2006 at 2:54 AM
2CARPRO JACK
  • 11,533 POSTS
The pump relay gets signal from the ignition switch and or the PCM. Removing the dash isnt necessary to fix the problem.Might want to find a tech with a little more experience in electrical troubleshooting
Dec 29, 2006 at 3:43 AM
Suggested Repair
Do not pull the dash or reroute power. Have an experienced electrical technician check the fuel pump relay and its signal from the ignition switch and/or PCM.
Conversation Summary
A 1994 Dodge Caravan quit running. The shop found no power at the fuel pump connector and said the pump would not run when power was applied, suggesting a dash teardown. The expert said the pump relay is signaled by the ignition switch and/or PCM, so removing the dash is unnecessary and a more experienced electrical technician should diagnose it.
