Thanks!
Ann
Replacing the BCM and instrument cluster did not restore the signals or gauges. Check the small wire and connector at the positive battery terminal, which one owner found loose and which restored the cluster and turn signals. Also test power and ground at the BCM and instrument panel before further parts replacement.
A Dodge Caravan lost turn signals, hazards, and dashboard gauges, and a scan tool could not communicate. The owner replaced a used BCM and later the instrument cluster with no change. The dealer found no cluster communication and suggested further diagnosis. An expert advised checking power and ground circuits at the BCM and instrument panel. Another owner reported the same symptoms were caused by a loose small wire at the positive battery terminal, and that report was welcomed as a useful addition.
