1994 Dodge Caravan Temp Gauge Fluctuates
LITATUDE
  • 9 POSTS
I wrote previously about my 94 dodge caravan 3.0 with @ 85,000 miles overheating and wanted to know if it cold be the water pump again. well unfortunately i was wrong but you were right about the head gasket. so we finally got that fixed but now the temerature gauge goes up and down quickly. when you stop the car it doesnt sound as if its boiling/overheating. So my new question is could it be the engine temperature sensor is sending the wrong signals to my guages making me think it is still overheating when it is not.
May 22, 2006 at 12:38 PM
SDALTON19
  • 87 POSTS
i would probabley say the sensor is ok they generally dont fluctuate like that when they fail what it sounds like is there are bubbles in the cooling system from not being bled correctley you may want to check you coolant level i'd be willing to bet thats your problem i hope this helps
May 25, 2006 at 2:13 PM
Suggested Repair
Check the coolant level and properly bleed air from the cooling system. A rapidly fluctuating temperature gauge is more consistent with air bubbles from incomplete bleeding than with a failed temperature sensor.
Conversation Summary
The owner of a 1994 Dodge Caravan said the temperature gauge rose and fell quickly after a head gasket repair, although the engine did not sound like it was boiling. The owner suspected a faulty engine temperature sensor. The expert said sensors generally do not fluctuate that way when they fail and advised checking the coolant level, attributing the symptom to air bubbles from improper bleeding.
