2000 Dodge Caravan Temp Gauge Drops on Heat
HUSKER
I have just put coolant in and now when i run the defrost the tempature guage starts to go down in the cool area. this is only when i turn on derost or heat?
Jan 15, 2007 at 1:02 AM
BACKYARDMECHANIC
  • 337 POSTS
Check the coolant level when the car is cold in both raditor and overflow.The coolant level is droping when you turn the heat on. This in turn causes the coolant to drop. The temperature sending unit is no longer making contact with the coolant due to the drop, causing the gauge to read incorrectly. Try topping it off and Good luck.
Jan 16, 2007 at 2:03 AM
Suggested Repair
With the engine cold, check the coolant level in both the radiator and the overflow bottle. Top off the coolant so the temperature sending unit stays in contact with coolant when the heater or defrost is turned on.
Conversation Summary
The owner of a 2000 Dodge Caravan said that after adding coolant, the temperature gauge drops into the cool range only when defrost or heat is turned on. The expert explained that the coolant level falls when the heater is used, so the temperature sending unit loses contact with the coolant and the gauge reads incorrectly. The advice was to check the cold coolant level in the radiator and overflow and top it off.
