1998 Dodge Caravan Speedo and Temp Gauge
1998 ALL OTHER MAKES ALL OTHER MODELS
TBONES18
Got a weird problem. The temperature gauge and speedometer does not work. Fuel Gauge works fine, as does the cruise control. When a scanner is hooked up, it reads no response. Drives and shifts perfectly. Also the odometer does not count up while driving.
Figure its not the speed sensor cause the cruise works. Maybe cluster? Although fuel gauge works. Maybe pcm? Any ideas?
Jul 22, 2006 at 12:30 PM
MIKEYBDMAN
  • 623 POSTS
Well, have you checked all of the fuses. It looks like Fuse 2 10 amp in the Juntion box ties into the systems you mentioned, but it also powers several of the instrument indication lights.
Worth a try. The next common thread is the Body Control Module. I believe the dealer can test this module, but not sure there is much you can do other than check fuses.
good luck.
Jul 22, 2006 at 1:42 PM
TBONES18
ya all those fuses are fine, i even went as far as to take out the whole box an check all wires an connections. Some corrosion there as was every box i seen in the wreckers.
Jul 22, 2006 at 2:32 PM
Suggested Repair
Check junction box fuse 2 (10 amp) and clean any corrosion in the box and its connections. If the speedometer, temperature gauge, and odometer still fail, have a dealer test the body control module.
Conversation Summary
The owner of a 1998 Caravan reports that the speedometer, temperature gauge, and odometer do not work, while the fuel gauge and cruise control do. A scanner shows no response, but the vehicle drives and shifts normally. The expert suggested checking fuse 2 (10 amp) in the junction box and then the body control module. The owner confirmed the fuses were good and found some corrosion in the junction box connections.
