1996 Dodge Caravan Fuel Filter
SEAN D. CULLEN
I have a '96 caravan, 3.8 litre with about 213,000 miles and need to change the fuel filter. can you tell me where it is and what I need to change it?
May 21, 2006 at 11:08 PM
VANDRAGON
  • 298 POSTS
Sean...the fuel filter is under the van on top of the gas tank. the fuel system has to be depressureized before doing the job. if you don't know what to do please take it to a shop. gas will spray everywhere and one spark could cause a really bad day...be safe not sorry.....vandragon
May 22, 2006 at 1:04 AM
Suggested Repair
The fuel filter is under the van on top of the gas tank. Depressurize the fuel system before replacing it. If you are not familiar with the procedure, have a shop do the job because fuel can spray and ignite.
Conversation Summary
The owner of a 1996 Dodge Caravan 3.8 with about 213,000 miles asked where the fuel filter is and what is needed to change it. The expert said it is under the van on top of the gas tank, the fuel system must be depressurized first, and recommended a shop if the owner is unsure because spraying fuel and a spark are dangerous.
