2005 Dodge Caravan Fuel Filter
LRP
does a 2005 dodge caravan have a fuel filter? I was told that it did'nt.
Feb 7, 2007 at 3:15 AM
BUBBA_KOSKI
  • 129 POSTS
yes they do
Feb 7, 2007 at 6:00 AM
FARQUI
Your van does have a fuel filter. It is an assembly consisting of a filter and plastic lines with fittings. You can purchase one through a NAPA store using part number CH38. It is a bit tricky getting to this filter. It is beside the fuel tank and the tank must be dropped a little to assist in removal.
Feb 9, 2007 at 10:38 AM
Suggested Repair
The 2005 Dodge Caravan does have a fuel filter. It is an assembly of the filter and plastic lines with fittings, available at NAPA as part CH38. It sits beside the fuel tank, and the tank may need to be lowered slightly for removal.
Conversation Summary
The owner asked whether a 2005 Dodge Caravan has a fuel filter after being told it does not. Experts confirmed that it does. The filter is a line-and-fitting assembly beside the fuel tank, sold as NAPA part CH38, and the tank may need to be lowered slightly for access.
