Need help again. I got my van up and going after I replaced the fuel pressure regulator. It was running fine for about 2 weeks, then all of a sudden with out warning It died at stop sign. It acted like it was out of fuel. Got it going long enough to get it back to the house. I checked to see if I had spark, I checked to make sure the fuel filter was not blocked. I confirmed that the fuel pump is engaging and pumping gas through the filter. I sprayed carb. cleaner into the air plenum. And the van starts right up. So does anyone have any other ideas to check on?
thanks,
Kyle
thanks,
Kyle
Mar 31, 2007 at 5:15 PM
