1998 Dodge Grand Caravan Cooling Fan
DAVID KIUNKE
I had the radiator replaced on my 1998 dodge grand caravan with 3.3 liter V-6 with 113,000 miles on it. The technician replaced the radiator and refilled it, when he was giving the final check-out he noticed that the fan never came on. He thought maybe a bubble of air was in the cooling system he used a special funnel and monitored the tempature with a diagonistic plug, and it read up to 217 degrees and the fan never came on. However when you turn on the A/C both fans run fine. What controls the fan when only engine tempature is envolved? Is there a fuse or relay to look for? I thought about just mounting a tempature switch on the radiator hose and tieing into the fan relay. What do you think?
Aug 27, 2007 at 3:25 PM
2CARPRO JACK
  • 11,533 POSTS
According to my software the cooling fan should turn on somewhere around 220 degrees, that isn't as hot as you might think for these newer cars.DO NOT splice in an aftermarket relay or sensor for the fan, it is controlled by the PCM and should be fixed to operate as designed. There is a fan controller near the bottom of the radiator that goes out which is a common problem.
Aug 28, 2007 at 12:35 AM
Suggested Repair
Do not splice in an aftermarket temperature switch or relay. The cooling fan is PCM-controlled and should come on near 220 degrees. Inspect and replace the fan controller near the bottom of the radiator, a common failure, so the system operates as designed.
Conversation Summary
After a radiator replacement on a 1998 Dodge Grand Caravan 3.3L, the cooling fans did not come on at about 217 degrees, although both fans run when the A/C is on. The owner asked about fuses, relays, and adding a hose temperature switch. The expert said the fan should engage near 220 degrees, is controlled by the PCM, and should not be modified with an aftermarket sensor or relay. A fan controller near the bottom of the radiator commonly fails and should be repaired so the system works as designed.
