2001 Dodge Grand Caravan Window and Fan
APAUSCH17
hi! I have a 2001 dodge grand caravan. The passenger side window will only work once in awhile. The heater fan used to work only on high speed and now only works sometimes. What could be the problem?
Feb 6, 2006 at 1:59 AM
2CARPRO JACK
  • 11,533 POSTS
the window sounds like the motor. The blower might need a fan speed relay or resistor which ever that car has
Feb 7, 2006 at 8:46 AM
Suggested Repair
The intermittent passenger window is likely a failing window motor. The heater blower that previously worked only on high and now works only sometimes may need a fan speed relay or resistor, depending on which the vehicle uses.
Conversation Summary
The owner of a 2001 Dodge Grand Caravan reported an intermittent passenger-side window and a heater fan that formerly worked only on high and now works only sometimes. The expert said the window issue sounds like the motor and that the blower may need a fan speed relay or resistor, whichever the vehicle has.
