2003 Dodge Grand Caravan Window Won't Work
SHIPPSTER
Would the non 1-touch switch work in place of a 1-touch switch?
I have a 2003 Dodge Grand caravan and the driver's side window switch has stopped working. It went out gradually and a Midas repairman said it is the switch.
I am pretty sure it was the 1-touch window switch, but it has been so long since it worked that I am not sure.
Anyway, on wholesalemopar.com the difference in price on the switches is around $30 for one with 1-touch and one without. My wife says she hates 1-touch anyway since she hits it by accident all the time. Can I just use the non-1-touch switch?
Jan 2, 2007 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
You would have to check the wiring schematic to see any differences in controllers or the way it is wired.If there are no differences then it would be ok to do it.Are you sure it is the switch? The motors go out just as often and do it gradually like you described.
Jan 2, 2007 at 11:11 PM
SHIPPSTER
Well, I thought it might be the switch and then the head mechanic at our local MIDAS said I was right. Is there an easy way to test it or the motor?
Jan 4, 2007 at 8:30 AM
STRATUS98
  • 96 POSTS
pick up a switch at the junkyard, and see if it works. I am not to familiar with the 03 but doesn't the switch come as a pack for the passenger side window as well? if that one works and the drivers doesn't I would lean more towards the motor. I wouldn't buy a new one, unless you are 100% positive its the switch
Jan 4, 2007 at 1:45 PM
2CARPRO JACK
  • 11,533 POSTS
If you remove the door panel, you can test for power and ground at the motor while operating the switch. Use a test light or meter.That test is free except for a little time
Jan 5, 2007 at 1:38 AM
SHIPPSTER
[quote:66fa009b99="2CarPro Jack"]If you remove the door panel, you can test for power and ground at the motor while operating the switch. Use a test light or meter.That test is free except for a little time[/quote:66fa009b99]
I'll see if I can find my Multimeter and try it tomorrow. Thanks for the suggestion.
Jan 5, 2007 at 2:47 PM
SHIPPSTER
[quote:ac1e34dfd5="2CarPro Jack"]If you remove the door panel, you can test for power and ground at the motor while operating the switch. Use a test light or meter.That test is free except for a little time[/quote:ac1e34dfd5]
I really hate my local MIDAS guy now. I checked the switch and had 12V for both up and down operation. So now I need to find some resources on how to change the window motor for my vehicle. I think that is a topic for another thread, but if you have a great one and want to share it feel free!
Jan 7, 2007 at 7:54 AM
2CARPRO JACK
  • 11,533 POSTS
They are all a little different.Some come motro/regulator as a package. Best bet is to get your new one and then you can see exactly what you are dealing with. If you have a digital cam, take pics as you go to refer to for reassembly if you should have a problem
Jan 8, 2007 at 1:45 AM
Suggested Repair
Do not replace the switch until it is confirmed. Remove the door panel and test for power and ground at the window motor while operating the switch with a test light or meter. The owner later measured 12V for both up and down at the switch, which points to the window motor rather than the switch. Window motors are often sold with the regulator; compare the replacement with the original and photograph disassembly for reassembly. Before substituting a non-1-touch switch, compare the wiring schematic for controller or wiring differences.
Conversation Summary
The owner of a 2003 Dodge Grand Caravan asked whether a cheaper non-1-touch driver window switch could replace a failed 1-touch switch after a shop blamed the switch. An expert said to compare the wiring schematic first and noted that window motors fail gradually just as often. Another reply suggested trying a junkyard switch and checking whether the passenger switch still works. The expert recommended removing the door panel and testing power and ground at the motor while operating the switch. The owner later found 12V for both up and down at the switch and concluded the motor needed replacement. The expert advised buying the motor or motor-regulator assembly and photographing the job for reassembly.
