1997 Dodge Grand Caravan Blower Only High
CRVNLVR97
1997 dodge grand caravan SE - 182K miles - where is the location of the blower motor resistor? I have only off and high controls for the heater and I purchased the resistor because I heard it was a pretty simple fix. Thanks!
Mar 18, 2006 at 7:53 AM
JPAM
  • 307 POSTS
if your referring to fan speed.. Off & High. highly, highly common in dodge products.. let me know what's going on.. Here is the location of the blower motor speed resistor which is solid state. Check out the images (below). Let us know if you need anything else.
Mar 18, 2006 at 8:00 AM
RAMVAN
The resisto is located on the firewall. at the upper left hand(passenger side) corner, under the cowl. Above the AC lines, and strut tower. It is an easy fix, you may have to replace the plug as well, it may be burnt. This apparently is a common problem in these caravans.
Mar 21, 2008 at 2:40 PM
BMRFIXIT
  • 19,053 POSTS
check the connector too they rust and burn
https://images.2carpros.com/forum/automotive_pictures/99387_resister_1.jpg
Mar 21, 2008 at 2:55 PM
Suggested Repair
Replace the solid-state blower motor resistor on the firewall at the upper left (passenger-side) corner under the cowl, above the AC lines and strut tower. Also inspect the connector and replace it if it is rusted or burnt.
Conversation Summary
The owner of a 1997 Dodge Grand Caravan SE with 182K miles has only off and high heater blower speeds and asks where the blower motor resistor is located. Experts say this is a common Dodge issue and identify the solid-state resistor on the firewall under the cowl at the upper passenger-side corner, above the AC lines and strut tower. They advise replacing the resistor and checking the connector, which often rusts or burns.
