1997 Dodge Grand Caravan Uneven A/C
MAPHEAD115
I have a 1997 Dodge Grand Caravan. The A/C sometimes works well but most of the time it hardly cools. The compressor, dryer, condenser, etc. have been replaced. I've noticed that the driver's side blows warmer than the passenger side. I'm wondering if the dash control unit could be the problem or if there is something else I need to check.
Mar 12, 2007 at 2:27 AM
CHEVY22
  • 1,375 POSTS
you can check the blend door on the passenger side and see if it is operating at all , when you change modes they open and close for what direction of air is commanded start there
Jim
Mar 12, 2007 at 5:00 AM
Suggested Repair
Check the passenger-side blend door and confirm it opens and closes when the mode setting is changed.
Conversation Summary
The owner of a 1997 Dodge Grand Caravan reports that the A/C often cools poorly and blows warmer on the driver side than the passenger side, even after the compressor, dryer, and condenser were replaced. The expert recommends starting by checking whether the passenger-side blend door operates when modes are changed.
