error code 04892307aa
1,000,000 MILES • V8 • 2WD • AUTOMATIC
PWALT46M
I am getting error code 04892307aa. I do not think it is my thermostat. The problem I am having is that I have duel climate controls settings in cab. The passenger side when placed on cool still blows out heat. The drivers side does get cold when turned to cold. Do you know why this is happening?
Mar 2, 2017 at 2:52 AM
HMAC300
  • 48,601 POSTS
it may be the control panel which should be scanned for codes by a mechanic or the actuators need to be reset. try pulling fuse M34 and M11 for sixty seconds with key on it may reset actuators and cure the problem.
Mar 2, 2017 at 4:13 AM
