Ac repair.
DODGE CARAVAN
MUMTO3
I have a 2002 Dodge Grand Caravan. I took it to a local garage for ac repair. They put die in it and filled it up with freon. It worked good for about 3 weeks. So I took it back they didnt find any leaks. What would you suggest I look for next??
Jul 24, 2007 at 8:20 PM
BPRICE443
  • 66 POSTS
You need to take it to someone that has the sniffer type of leak detector they find leaks right away. If it's not leaking anyware they can see then it may be the evaporator or the compressor shaft seal.
Brian
Jul 25, 2007 at 10:43 PM
