2002 Dodge Caravan AC Leaking Inside
DAN15
2002 Dodge Caravan, 75,000 miles. Condensation from the air conditioning leaking into the passenger compartment. Tried to open the drain on the engine side by pushing a wire into the tube--still not working. We get a small amount on the ground; however carpet drenched. Any help appreciated.
Jul 25, 2007 at 1:09 AM
BOOTDOG
  • 665 POSTS
the tube is still clogged. try using something a little more sturdy, like a wire close hanger. good luck
Jul 25, 2007 at 9:28 AM
PIPER249456
Mine does the same thing but we are having a terrible time finding the tube. We can't see it from above or below. Can you direct?
Jul 31, 2007 at 1:10 AM
Suggested Repair
The evaporator drain tube is still clogged. Clear it with a sturdier wire, such as a coat hanger, until condensate drains outside instead of into the carpet.
Conversation Summary
The owner of a 2002 Dodge Caravan reports air-conditioning condensation soaking the passenger carpet. Probing the engine-side drain with wire produced only a small amount of water outside. An expert says the tube remains clogged and recommends clearing it with a sturdier wire such as a coat hanger. A later comment asks where to find the tube, but that question was not answered.
