1996 Dodge Caravan AC Intermittent
USAPATRIOT
I have the van mentioned above and it's having a problem with the A/C. Sometimes it cools just fine. Other times it blows hot air. It may do both in the same trip. Turning it on/off may or may not help. On occasion the belt will squeal, other times not. Sometimes when I turn the unit on I hear what sounds like fluid flowing, sort of a hissing sound, which lasts for a few seconds.
The van has an odd electrical fault that seems unconnected to this. At times the windshield wipers will start up on their own, wipe once or three times and then stop. It's most likely to happen when it's cold and humid. No other odd things happen.
I'm disabled, REALLY need these wheels and it's actually a very nice running vehicle...except for the AC and wipers. Thanks for any help you can give.
Aug 29, 2007 at 7:16 AM
2CARPRO JACK
  • 11,533 POSTS
If the presures are good and the belt is ok, then it sounds like it could be a sticky expansion valve causing the problem for the a/c as long as the compressor is running when it isnt getting cold.Thw wipers and a/c go through the Body Control Module, so if the a/c comp isnt running sometimes and the wipers do their own thing on occasion, the BCM could be the culprit. Remove the plugs and be sure all connections are clean and tight. BCM is on junction block under left side of dash
Sep 4, 2007 at 12:59 AM
Suggested Repair
If A/C pressures and the belt are good and the compressor is running when the air is not cold, suspect a sticky expansion valve. Because the A/C and wipers share the Body Control Module, also clean and tighten the BCM connectors on the junction block under the left side of the dash.
Conversation Summary
A 1996 Dodge Caravan with 170,000 miles sometimes cools and sometimes blows hot air, with occasional belt squeal and a brief hissing sound. The windshield wipers also start on their own, especially when cold and humid. The expert said a sticky expansion valve is possible if pressures and the belt are good and the compressor is running, and that intermittent compressor operation plus the wiper issue could point to the Body Control Module. They recommended cleaning and tightening the BCM connections under the left side of the dash.
