My AC will has not blow cold air since I bought it. Recently I wanted to try to fix the problem. So I bought an ac recharge kit and refilled the system to the proper pressure. However the gauge reads the same when the system is on or off and also when the van is off. The clutch is engaging and the system blows air (hot). I checked the fuses but they are all fine. Any ideas as to what could be causing the problem?
Aug 17, 2010 at 1:46 PM
