2001 Dodge Caravan one side of heater blows hot air
THOMAS VANDAL
  • 2001 DODGE CARAVAN
Heater problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 108k miles
when we turn on the heater only the driver side gets very hot air like it used to, but now the passenger side gets cold air only.I checked the anti freeze levels and there ok what else can be causing this and how do I check to find out
Thursday, October 7th, 2010 AT 2:58 PM
WRENCHTECH
  • 20,761 POSTS
Is this a dual temp control system?
Thursday, October 7th, 2010 AT 3:11 PM
THOMAS VANDAL
I dont know how can I check to find that out
Saturday, October 9th, 2010 AT 1:36 PM
WRENCHTECH
  • 20,761 POSTS
It's pretty obvious. Do you have separate temp setting for left and right?
Saturday, October 9th, 2010 AT 1:38 PM
THOMAS VANDAL
Saturday, October 9th, 2010 AT 1:40 PM
WRENCHTECH
  • 20,761 POSTS
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Saturday, October 9th, 2010 AT 1:41 PM
THOMAS VANDAL
Is that easy to get to and cheack or is it a job for a pro
Saturday, October 9th, 2010 AT 1:52 PM
