2005 Dodge Caravan Leaks on the inside of van
40,000 MILES • 6 CYL • FWD • AUTOMATIC
GRAMMA2DAY
My air conditioner blows cold air but after about 15 minutes it stars leaking on the inside of the van. I took the dashboard off and can see where it is coming in the van, but I can't seem to get to the air conditioner (not sure exactly where it is). What is causing this leak & How do I access the air conditioner to locate the cause of the leak?
Jul 26, 2008 at 6:07 AM
DOCFIXIT
  • 18,828 POSTS
It is the condensation drain tube.Located pass side down at bottom of box. You can get to from under van look you will see a rubber hose pointing down clean it out.
Jul 26, 2008 at 6:47 AM
GRAMMA2DAY
Thanks for your help. I found the hose and flushed it with the garden hose. I still have a leak on the inside of the van.
Anything else that may be causing this?
Jul 26, 2008 at 7:13 AM
DOCFIXIT
  • 18,828 POSTS
Did you flush from the tube end towards car?
Jul 27, 2008 at 5:58 AM
