Where is the fuel filter?
ATXT63
  • 6 POSTS
Could the filter be located closer to the engine in a different module?
Thursday, December 17th, 2020 AT 8:42 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
NO
you dont have one
the only place they put it was on top the fuel tank
or in the fuel tank with the fuel pump
what you have is the one with the fuel pump
so if you have no prob leave it alon
ATXT63
  • 6 POSTS
The problem is the car hesitates when you press on the gas while driving and sometimes has a slight hesitation when at a light. I have changed the air filter and done an oil change. It started after I put I think some bad gas in it. I have also put some fuel injection cleaner solution in for the 2 fillups but did not on the last one. Should I continue to add the injection cleaner till it runs smooth? The engine service light came on after getting the bad gas, went off after adding two injection cleaners, but came back on after the last fillup.
BMRFIXIT
  • 19,053 POSTS
Have you changed the plugs and wires
I think van do for a tune up
also try next time you go for a fill up to add some dry gas
in to the tank before the fill up
ATXT63
  • 6 POSTS
I will try that. I think the plugs are good till 100000 miles. Should I get the fuel injectors cleaned or use the same solutions or maybe a water remover solution till it smooths out? Thank you.
BMRFIXIT
  • 19,053 POSTS
Just try tune up for know with dry gas (water remover solution )good luck
let me know
TWEETY20
  • 2004 DODGE CARAVAN
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic
where is the fuel filter how do I replace it
Saturday, December 19th, 2020 AT 9:17 AM (Merged)
  • 110,029 POSTS
The fuel filter is in the tank and part of the fuel pump module. To replace it, the tank needs removed. Here is a picture of the beast:
https://www.2carpros.com/forum/automotive_pictures/249084_gas_1.jpg
I hope this helps.
