1998 Dodge Caravan Radiator overfill turned coffee brown co
RICARDO GOODMAN
Engine Cooling problem
1998 Dodge Caravan 6 cyl Two Wheel Drive Automatic 89000. miles
Radiator overfill turned coffee brown in color as well as the transmittion fluid in the trans refill dip stick. The odd color fluid began leaking from the front of the car and the car reved before it went into gear.l
Feb 27, 2010 at 12:53 AM
GWOLKING
  • 10 POSTS
[quote:98b4875b4b="Ricardo Goodman"]Engine Cooling problem
Radiator overfill turned coffee brown in color as well as the transmittion fluid in the trans refill dip stick. The odd color fluid began leaking from the front of the car and the car reved before it went into gear.l[/quote:98b4875b4b]
Sounds like the transmission oil cooler is leaking inside the radiator. If so, DO NOT START THE ENGINE OR DRIVE THE VEHICLE or you risk completely trashing the transmission. The radiator will have to be replaced, and the transmission will require a thorough flush.
Feb 28, 2010 at 5:53 PM
