1998 Dodge Caravan My gauges Are Moving The
133,460 MILES • 6 CYL • AWD • AUTOMATIC
DINK05
my gas guges read empty and my hand on the side that has the numbers is in the red zone what might that be?
Apr 14, 2010 at 12:34 PM
CH112063
  • 1,320 POSTS
If your fuel sending unit is bad on the fuel pump, or the gauge in the cluster has a bad connection, this happens, I don't understand the other hand.
Apr 14, 2010 at 2:03 PM
DINK05
ok so it the fuel pump what i meant was that the area with the numbers on the leftside next to the spedometer is stuck and gas gauge reads empty and when i cut the van off u can still see prd light on when the vehicle is shut off?
Apr 14, 2010 at 10:08 PM
CH112063
  • 1,320 POSTS
Your tachometer is pegged all the way to the right and does not move. And the fuel gauge does not operate. The PRNDL lamps is what I am concerned with. There were so many problems with these newer ignition switches which feed the bosdy, transmission and powertrain modules that it may be a bad switch, yet the cluster it self is on the bus wires and are controlled by three seperate modules. Fuel gauge operates by the sending unit sending a signal to the body module, it operates the guage, tachometer originates at the two sensors but the signal is heard by the powertrain module from the TCM,. I would try to operate the faulty item. Jiggle the key to see if it changes anything. Then take the lens and cluster out or try hitting it to see if it changes anything. All this takes time. A technician can use a DRBIII to read faults in any of the computers and test each of the problems you have. Without the scanner you'll have to try the first things I spoke of with the key and cluster. Other then that you'll need a scanner to be sure. We don't have many problems with the fuel gauge. The body computer is usually good if it has not failed by now. You may have a bad ignition switch or cluster circuit board, try to duplicate the problem. See what happens and let me know, ok dink05
Apr 15, 2010 at 1:36 PM
